1 - 12 of 12 Posts
Just Having Fun!
I just started having this problem a few days ago. The LED display is only half like a glass half empty, hope that makes sense. I plan on going to the dealer after work today since it not correcting itself. The DIC in the middle is working fine as well as all the analog gauges. Anyone else have this problem?
Will show a pic of it tonight.
Former user
Thread title sounds like a personal problem :gr_jest: j/k
Do you mean only half of the display is showing at all or is it just half as bright as it was?
Turbo Whistle? She's Stock:)
Could be a fuse. Dismount the panel under the steering column and check for a blown 10A mini fuse.
Suffering Fools
Just Having Fun!
Discussion Starter #11
Finally had the cluster replaced under warranty. Had to keep the car an extra day since they had to have one shipped overnight. Its nice to see the displays again! :thumbs:
Curious what the replacement cost when the warranty is up on these cars.
A customized NEW replacement from Chris White will run you from $550-$700 depending on options. This assumes he has them in stock, and his prices vary. I've seen them going on eBay for low to mid $300's (used, of course).
1 - 12 of 12 Posts
