1 - 20 of 156 Posts
GM Performance LSX block. 4.185" bore
Callies Dragon Slayer Magnum crank 3.825" stroke double keyway
Callies Ultra Billet rods 6.125" length
Total Seal ring pack
Callies HD wrist pins
Moroso oil pump
Moroso front sump 6qt pan
Moroso remote oil filter
Moroso crankcase evacuation pump
-12 AN oil lines
Schneider Roller cam, .650" lift, 270* duration 118*LSA
Brodix BR7 heads, 2.250I 1.65X, CNC ported
Double roller chain
ATI balancer, HD hub for blower app, double keyway
ARP top end/bottom end studs
Injector Dynamics 1300x'2s injectors
Injector Dynamics 750 filter
Fore boost reference fuel psi reg
3x Walbro 450 fuel pumps. One master, two boost referenced
-8 AN fuel feed, -6 an return
Mezeire LS1 water pump, electric
Bar stock machined rear engine cover, I made
2.9L LS7 type Whipple supercharger
109mm Whipple Throttle body
Whipple remote IAC
MSD coil packs and wires
Kooks headers
3" SS exhaust I fitted/welded myself
Borla XR-1 mufflers
Crower 1.8:1 shaft mount rockers
Crower 3/8" pushrods
3 bar Map, GM
My own designed, modeled, and machined independent 10 rib Serp belt direct blower drive conversion
V flange header flange conversion
Wilwood brake kit, all 4 corners. GR2 rotor upgrade
AFCO coil overs, rear
ForgeStar Wheels, 285 Michy pilot rubber-street driving
ForgeStar Wheels, Micky Thompson 305/35's for street class racing
Weld 15x10 drag pack laced with MT 28x10.5x15 Pro Bracket Radials for racing
G Force Mini Tubs
Analog instrument upgrade, boost, fuel, oilpsi, oil temp, wideband. All matched to OEM gauges.
Battery relocation
One off board and relay setup for fuel pump management/
Machined 3x fuel pump hanger.
EMT fluid pump for intercooler.
Mishimoto radiator/hoses
AC driven interchiller
Extreme Automatics 1500hp capable 4L80. Full manual valve body, trans brake
Circle D Flexplate, alloy
Circle D converter, 2400rpm stall
G Force Engineering/Strange Engineering alloy 9" 3rd member/rear end conversion 3:55 gears.
G Force Engineering 2500hp Outlaw axles
G Force Engineering 2500hp rated outer axle stubs
Notched lower control arms
4" alloy driveshaft
Morel roller lifters
Mechman 240amp billet alternator
Custom pistons from McCabe Motorsports in Colorado Springs, CO.
UPDATE 8.17.18:
Estimated power: At 12psi on E85 were hunting for 1000hp flywheel. Have not dyno'd the engine yet.
The list goes on. . .
2006GTO M6 dd-drag-roadcourse
Yeah you should be able to break the 400rwhp mark with that set up :rofl:
But seriously nice build :hbang:
4l60e heavily modified, as in what? I think no matter what you do the sun shell and planets are not going to hold that kind of power. I’ve seen the sun shell (beast) spread apart around 700hp.
I agree, lol.
Back story is I bought this car new in 05. Built it up (1st time) in 07. Hung onto it till 2010 when I sold it to to help start my business. Friend bought it and he started killing tranny's left and right. He finally had the one built that's in the car now. I don't know exactly what he had done to it. He basically said "everything" just short of a manual valve body and trans brake.
I bought the car back in Nov of 16. Still has that transmission in it. For now it'll stay there as the engine gets completed, broke in, etc. Plan to yank it out and replace either with a 4L80 or a TH400. I'll do the rear end with a G Force 9" setup at the same time.
Discussion Starter #11
That's gonna be a fun hell raiser. What is the end goal for numbers? Hp/tq
Sent from my SM-G950U using Tapatalk
I initially set the target number at 1K to the wheels. I've had several deep conversations with Bill P, the owner of the king of kings, "Ethyl". A gto that made over 1200.
Based on his experience and the headaches he went through, I'm regrouping a bit. I hope to run this in the 900-1000 range at the flywheel. The rest will be what it is once it hits pavement. This IS a street car. A stupid one for the most part, but a street car. My end game is to be able to drive this anywhere I want whenever I want. I want it as solid as any modern production OEM performance vehicle.
So, we go slow, we go methodical. For where I live, I'll be able to lay plenty of hate on the street. Not too much going on around here. The track is a different story, we do have some heavy hitters, but they trailer stuff everywhere.
Fun!
The battle of wits has begun.
The machined pieces look fantastic.
Granted everything I do on my GTO is of a non-existent budget. But I agree with your statement of an enjoyable "street car". When you have to trailer it places rather than driving / enjoying it... then its not a "street car" anymore.
That said, simply amazed by the work your putting into it.
Single Digit Stick Shift
Fantastic build... I don't want to make you nervous (just aware) but did you have the cylinders sonic tested for thickness?
http://www.chevytalk.org/fusionbb/showtopic.php?tid/289661/
That was from the first version of the LSX blocks. The cylinder walls were too thin. Since then, they have gone back and redesigned/strengthened the area of failure. If he has a 2nd version LSX block then he should be good to go without worry.
Callies DS crank 3.825" stroke double keyway
Callies UB rods 6.125" length
Weisco forged pistons
JE rings
Moroso oil pump
Moroso 6qt pan
-10 AN oil lines
Cloyes Z chain
Whipple remote IAC
Kooks headers
Custom 3" exhaust
Custom (as in made myself) 3" turbo mufflers loosely based on Borla's 2004 GTO mufflers
3 bar Map, GM
Custom designed, machined 10 rib Serp belt direct blower drive conversion (still in process)
V flange header flange convesion
4L60E trans, heavily modified
1pc DSS drive shaft
Wilwood brake kit, GR2 rotor upgrade
Coil over convesion, BC
ForgeStar Wheels
Michy pilot rubbers
Full instrument upgrade
Holley EFI Dominator ECU conversion (still in process)
Battery relocation
Custom made board and relay setup for fuel pump driving
Custom machined 3x fuel pump hanger.
Nice
Beautiful build. Please PM me your contact info. I've got a couple of questions for you.
Thanks,
Mike
Discussion Starter #19
Early GM LSX blocks had issues. Half a decade ago. It's been worked out.
New stuff is known to run just fine. Considering it took over a month to get the case, I'm betting what I have is latest production.
So far so good. Still lots to do...
In for results! I have a similar build as yours. You have way more cam and lift (especially with the 1.8:1 rockers) than I do though. I’m expecting close to 1000hp at the crank with around 13-16lbs boost on E85. With the 1” blower spacer that has nitrous spray bars I’m shooting for 1200-1300hp crank. Awesome build!
1 - 20 of 156 Posts
