1 - 6 of 6 Posts
Would you guy rather go with LS6 heads or Z06 heads?
Z06 heads # 12564825
This is a bare head with guides, seats and plugs. Z06 Exclusive Cylinder-Head Design At the heart and soul of the LS6: unique cylinder heads for better engine breathing. Larger ports than those in the LS1 engine also improve airflow by 10 percent. Compression ratio is a healthy 10.5:1.
LS6 heads # 12564824
This cylinder head is used on 2002 Corvettes with 405 HP RPO LS6. The LS6 cylinder head can be used on any Gen 3 design V8 block. This LS6 head is emission legal on the 2002-2003 Corvette only. It includes the following items: 12564825 Head - Bare 12565313 Valve Spring 10166344 Cap, Valve Spring, capable of 550" lift cam 12565311 Valve, Intake, light weight 12565312 Valve, Exhaust, light weight, sodium filled, hollow stem 10166345 Key, Valve Stem 12482063 Oil Seal, Intake 12482062 Oil Seal, Exhaust
Those LS6 heads are the part number used for the autocross version.
http://www.highperformancepontiac.com/features/0405pon_gtoautocross/
It apears that if you go with the Z06 Heads you have to get the valves to go with it.
Z06 intake valve # 12565311
Z06 exhaust valve # 12565312
What do you all think?
Yes, it has a car seat
If I were to upgrade heads - I'd be looking aftermarket rather than GM. I would purchase complete - because headwork is something I've never tried on any vehicles yet - and with this one I'd be really scared of messing something up.
Dan
This has been covered numerous times. For the same price, you can get more aggressive sets of heads (and cam) from aftermarket suppliers like Patriot, GTP, AFR and a few others vs. the LS6 units. The LS6 heads (and cam) are a mid level setup vs some of these others.
And to be honest with you, these aftermarket heads are GM castings that are custom worked anyway.
The only way I'd stick with the LS6 units would be if you wanted to say you had genuine GM performance parts on your car.
1 - 6 of 6 Posts
