Has anyone used these rotors yet on an 05 or 06 GTO?
http://www.wholesaledirectparts.com/browser.asp?ItemCodeId=1941744575&showcase=yes&Start=0&EDI=3-4-8-116-234-111-74-80-78-153-198-56-240-186-106-249-34
Path: All Makes\Pontiac \2005\GTO
F-R Slotted Rotors And Pads KIT
Package Includes:
2 Front Slotted Rotors
2 Rear Slotted Rotors
Front and Rear High Performance Brake Pads
Bendix Slotted Brake Rotors are for drivers who want to improve the looks and performance of their vehicle's original braking system without having to change additional brake components. Bendix Slotted brake rotors provide excellent stopping power in everyday traffic, as well as more spirited, high performance street and highway driving.
Bendix Slotted Brake Rotors match the vehicle's original equipment rotor's dimensions and are fully compatible with its hubs, brake calipers and road wheels. Bendix slotted brake rotors are available to provide a matched appearance on all four corners of the vehicle, and employ one-piece vented or solid rotors depending on the vehicle's original equipment specifications.
Starting with select castings, Bendix slotted brake rotors undergo the race-born practice of slotting to clear gasses and clean pads for a better bite resulting In up to 40% better stopping power.
Bendix slotted brake rotors are zinc coated for corrosion resistance to help eliminate rust and to offer a bold, aggressive appearance to enhance the look of the vehicle's road wheels.
Bendix slotted brake rotors are designed to meet the challenges of high performance street driving while adding an authentic, race-ready look.
NOTE: BRAKES ARE A SAFETY CRITICAL PART OF A MOTOR VEHICLE.
Brake components should be installed by a competent mechanic in a professional manner. Any incorrect installation of brake components can cause a major safety problem or an accident. If you are not a competent and qualified mechanic you should not attempt to install these products, but should take the vehicle to a vehicle dealer or competent automotive mechanic for their installation.
Disc brake pads and rotors are wear items and as such, should be inspected regularly and replaced as necessary.
Buy Qty Sku Name Price
WDPKIT7316-S GTO Front And Rear Power Stop Slotted Rotors And Axxis Metal Masters Brake Pads Kit $291.00
Package Includes:
