RPM Level 6 trans with billet output shaft, also include quick connect fittings and increased capacity oil pan. 4000 Stall Pro Yank Torque converter. PTS 1 Piece Carbon Driveshaft 3.75" with HD joints
All parts have less then 6k miles.
$5000 for everything
Parts cost new:
This trans is $4000 plus core
Driveshaft $1650
Yank Converter $1100
Work done to trans:
  • Media Blast Transmission Case
  • RPM Level VI 3-4 Clutch Pack
  • RPM Reinforced Sunshell with Collar and Bearing
  • 4L65E Low Roller Clutch
  • Billet 4th Gear Servo
  • Transgo HD-2 Shift Kit
  • Corvette Servo
  • Wide 2-4 Band
  • Updated Aluminum Accumulator Piston
  • Bushing Kit
  • New Shift Solenoids
  • New GM Valve Body Spacer Plate
  • GM Filter
  • RPM Spec Clutch and Band Clearances
  • Seal & Gasket Kit
  • RPM Sleeved Input Drum
  • Billet Over-Run Piston
  • GM 5 Pinion Planetary Gearsets – Front and Rear
  • Extra Wide, Heavy Duty, Double Caged 29 Element Sprag
  • 300m Billet Output Shaft
  • Dyno-Tested Before Shipping
