1 - 2 of 2 Posts
It started yesterday I couldn't get the shifter to "stay" in 1st gear it would pop out of 1st gear after rolling about 10 feet it would slide into 1st I will add that it shifts smoothly from 2nd to 6th & going to reversed isn't a problem...yet. I checked the clutch reservoir it was a little low so I filled with DOT4 brake fluid but the problem persists. PLEASE HELP!!!!!!!!
Here is link to T56 manual...Look up trouble shooting: https://www.tremec.com/anexos/TRSM_T56_0711.pdf
You said you added fluid,ever flushed it? ,,Better look up "Ranger method" on hydraulic clutches and proper maintenance on clutch fluid.
1 - 2 of 2 Posts
