GTO Rear Seat Delete kits
We now have the 2004-2006 GTO rear seat delete kits made with an unbreakable ABS Plastic platform, heat molded to the shape of the interior panels, and covered in high quality black carpet. We are the only manufacturer to use this exclusive design, and all units are built here at our NC facility. The net weight loss is 37-40 lbs from your GTO.
The lower panels are 3/16" thick ABS Plastic for added durability, with the rear panel measuring 1/8" thick and supported by hidden custom brackets. Entire kit is removeable when needed.
The ABS plastic base will not break or crack under heavy weights. Can easily hold the weight of a human or large animal without any warping or sagging. Special brackets, hardware, and detailed instructions included. We use factory bolt holes for mounting, with use of plastic push-pins instead of unsightly screws. Works great as a mounting location for nitrous bottles or stereo components.
CURRENT SALE PRICE: $199.95
More details and Order page:
Http://www.rearseatdelete.com/gto.html
