21 - 40 of 59 Posts
Discussion Starter #21
I will say, I could put the car back to stock pretty easily and I don’t feel like I ruined my car, but it would take some fabbing. I built the kit around the car mainly. The piece I cut out in front of the fender I can easily put back. And then put the ps cooler back on. The lines bent out the way wouldn’t hurt them to stay where they are. This isn’t a hack job by any means, it’s just I went through great lengths to make this reliable and not burn stuff up and be easy to change plugs and easy to work on. I can have tho whole kit off the car in less than 20 minutes after putting the car up on ramps. Probably less time than that actually.
1 of 40,757
LOL if you havent seen my build thread, I already have the same manifold on my car.....i'm building a slightly improved version than mine. Mine has been going for two years so far with no cracking or problems besides having to move the v band
Ah, yes you did. The cast manifold version you did is more memorable. lol
Discussion Starter #24
No sir, that idea got scrapped at the beginning. I did not like how it was going to end up. I had posted a pic of that atrocious contraption and then abandoned ship on it. It never went on my car. I have had a log manifold like this from the very beginning............you lost track of the tread? :(
Discussion Starter #25
Got some more done. Trucking along much faster than I did on my car. I guess because I know exactly what I need to do and where I want to end up even tho I’m tweaking things to fit a little better than mine.
Discussion Starter #26 (Edited)
Aight pimps. Worked on it some more last night. I wasn’t happy with cylinder 7 spark plug boot clearance. I probably could have called it good, but that’s not how I roll
too tight
Can now fit a 5/16 drill bit without the sleeve
and starting on the crossover pipe inlet
Super Moderator
That looks amazing! can't wait to see you merge that port into the step down portion of the log.
Discussion Starter #28
Thx. Look at the pic with the drill bit, that tube is in there. It flows perfectly into the transition. It’s not tacked in place yet because it not being there is easier access when building the crossover inlet.
Super Moderator
Yeah I saw that I guess in my mind I was thinking more about boring the hole and finish welding it. I assume you are using a holesaw to open up the log? Is it super critical in a turbo manifold to ensure there is no lip inside after finish welding?
2005 Pontiac GTO
Is that the #7 cylinder, not #8? I'm trying to figure out the rest of the plumbing based on it being #8 and it wasn't making sense. Looking at yesterday's picture, that's definitely #7. Looks really good!
Discussion Starter #31
I was trying to see how many of you were paying attention.
j/j good catch. My coffee hadn’t kicked in yet lol
Discussion Starter #32
Ahh ok.
I used a hole saw on my manifold. It was a bitch. I think I’m gonna use the plasma for it this time. I’m going to practice first on a few pipes and see how that goes.
what I do is use a carbide scribe and outline the tubes once tacked in place. I’ll rough in the hole then I’ll die grind it close to my scribe line. It should not have a lip because this stuff is about 1/8 wall. (.120) I’ll post the holes once I get there. Probably sometime this weekend. I do have to work all day Saturday so I won’t get as much done as I’d like.
Super Moderator
Hows it going Kfx?
Discussion Starter #34
Sorry fellas. This got put on hold. I went on vacation and the week before it, I had lots to do before we left. We went to Panama City beach for 7 days and we just got back today. I’ll resume on this project in the next day or so. Gotta recuperate.
Discussion Starter #37
Yo my dudes. I’ve been busy slacking. Lol. I’ve worked on it a bit but nothing worth posting. Had to redo the down tube to the crossover. I didn’t like the steering shaft clearance it had. All good now
Aight fellas. Pulled the car in my shop this weekend and got started last night. Little backstory. I live in a neighborhood that doesn’t allow large builds on our lots. Well they didn’t when I bought my building. I bought the biggest one they would allow but it’s off the ground and I’ve always been afraid to drive a car in it. I finally ended up doing it with my car not long ago and it was fine, so I drove this gto in it to build the turbo kit. I insulated my shop, I have a 12k AND a 15k ac units in it. 70 degrees in the heat of the summer. Problem is, it’s small. 18x24, so not ideal for vehicles but I can make due. It’s got plenty of room for one car tho. This is a far cry from what I’m used to. I’m usually working on my car on the driveway or under the carport. Heat. Cold. Sun. Rain. So needless to say, I’m excited. I’ll post a couple pics of my little man cave shop for those maybe interested. Most importantly, all my tools and stuff are in one spot, my tv is in there so I can watch YouTube while I work and I’ll be comfortable out of the elements. Yay. Lol. Anywhoo. Please comment, give feedback, say hey or pat me on the back while I’m doing this, so I won’t feel like I’m wasting my time posting this for you guys. :)
here’s my little shop.
Right before I filled it up with stuff and put down padding over ha the floor (I workout in there too)
I ended up getting more Mat like this
Man this is beautiful, I just have my crappy garage that my car barely fits in.
21 - 40 of 59 Posts
