So I have been pondering supercharging my GTO.
I want PDS so no Procharger here. Not even an consideration for me.
I want low end torque with next level HP over the stock car.
I am running a GMPP crate motor which has the LS3 heads on an LQ9 iron block. which yields 10.3:1 compression ratio so blower friendly
But cast pistons and daily driver status, leaves me in the "lets keep it reasonable" mode.
So the easy option would be LSA supercharger, but my tuner feels the TVS2300 would suit the car better.
Plus from reading on here it looks to have better hood clearances from those who have done it.
Dream world right now is TVS2300 with 9lbs'ish boost with a NA stage 2 cam which is what he would do.
He feels it would allow us more latitude since the dynamic compression would be less at lower rpm, and would allow us to push for more
timing up top.
Flip side is the OEM look of a LSA supercharger. And a more friendly price and some of you have made some stout numbers with that combo.
I have been reading all I can find on here and it seams that the old threads showed that the availability of a combination
of a rec port tub and middle offset drive assembly was a challenge to get put together. I have read it was done but not a buy it option.
From what I can see it looks like you buy a GTO kit and buy a separate rec port bottom manifold.
Is that still the case?
and for a mild daily driver that is a weekend toy is it worth it?
For a long time to come I want to leave the bottom end of the motor alone since I just paid for the crate motor.
Let the opinions FLY!
timing up top.
