1 - 12 of 12 Posts
--Insert witty comment here--
Somewhere along the way, I lost the sheet with the part number from Caspers for the 02 sensor extensions. The ones I bought locally didn't hook up right, so now my car is running pig rich. I need to order them first thing in the morning.
HELP!
One a side note, I'll have pics up soon of my mandrel bent 3" duals, and yes, I cut the bumper, LOL.
:D
DAAAT'S RIGHT
Thanks! I know the instructions said to order an 8" extension, but I guess longer is better...
On a side note- Did anyone notice how close the tubes come to the rack and hard lines? I have barely 1/8" or so near one of the lines. Should I bend the lines a bit, or dimple a header tube?
Thanks again.
Congrats. I think you're one of the first to do the entire S/W exhaust, headers and all. Let's hear it!
You cut the bumper ? This i gotta see.
Don't worry, he hired a specialist
Oh my f*ck!
Sam 04 GTO said:
Eh, I can't figure out this new FTP program I've got, if anyone wants to host 'em, I can send the pics.
Have you tried the "manage attachments" button when you make a new post around here? Shouldn't need to host em...Just keep it to 5 pics or less per post and I think a max of 250KB/post or something like that.
Ludicrous Speed!
I just spliced in some 12 gauge wire on the front O2s, soldering each joint, heatshrinking and then taping the assembly. Took about 5-6" of additional length to work. The rear O2s reached with a bit of tweaking, no extension required.
As for the clearance, mine isn't too close to the hard lines, but I did heat and massage one pipe that was almost touching the top rubber seal on the rack itself, right below where the steering shaft joins it.
4L60E+moded ls1+saudi = bad
Please , stay away from my car :gr_jest: :gr_jest: :gr_jest:
1 - 12 of 12 Posts
