1 - 4 of 4 Posts
I’m having a occasional problem with it starting...sometimes I get in and turn the key and it starts for approximately 3 seconds and then turns off. Then I turn the key again few times and won’t turn over at all. But I found that if I push the unlock button on the key then it starts up correctly. I took it to the dealership and they said it was the computer and repaired it but that did not fix it. Any ideas? Thanks
Usually a dirty ring around the ignition. I think most use rubbing alcohol to clean it. I have the same issue, first thought it was the ignition switch and did that work for nothing.
it’s part of the VATS(security system).
Thanks everybody, I ordered a new key fob and will set that up and see what happens. I’m wanting to list this car for sale but I don’t want to have any issues for the new owner. 100% stock 68,000 miles
1 - 4 of 4 Posts
