1 - 2 of 2 Posts
Dismembered
So, is this possible? I was hoping I could use an aftermarket guage (specifically the Autometer Ultralite) with the stock oil sending unit....
Nope. The factory sending unit is an input to the ECU so you can't disconnect it or tap into it as that will alter the oil pressure signal and trigger a warning.
You need to install an additional sensor either in an alternate location (not sure where there is one) or in the stock location with a "T" to keep the factory one.
1 - 2 of 2 Posts
