Status
Not open for further replies.
1 - 20 of 92 Posts
I just bought a 2004 goat and I did have the money for a cat back system. I took off the stock mufflers and ran straight pipes for a more aggressive sound. It sounds awesome but, I noticed a significant difference in throttle response and low-end torque. Should I get it tuned or just keep saving for full exhaust (headers and cat back).
The DAR
I took off my mufflers a while ago just to see what it'd sound like. I didn't notice any sort of throttle lag or torque loss at all.
Meh, my jet is faster...
Ditto....I've just noticed I can't hear the tires burning as easily:gears:
I have heard a lot of people complain on loss of torque loss with straight pipes. I have been considering this but alos wanted to see if anyone has a positive answer on torque loss.
considering it does it to every single other NA car in existance... the gto would be no exception. take the mufflers off, then put them back on, you'll notice a difference.
12 Second club
I have longtube headers, catless mids, and resonator deleted on my car. I unbolted the Magnaflow mufflers just to see how loud it would be, and drove around for a couple days.
The car sounded AWESOME, but was a turd and slow.
ManBearPig, I'm super cereal!
Well, from experience, I can tell you that when my cutouts are open (pretty much straight pipes at that point, cutouts are under the rear passenger seats right after my H-pipe) my car sounds badass, but it "feels" slower. The tires don't spin as easily (I can hear them when the windows are down), and the car just feels sluggish. Close the cutouts, and the exhaust goes through my flowmaster super 40s. Car feels fast again, tires spin like crazy now. So yes, you WILL lose torque due to a lack of backpressure. It is not a myth.
lol
when i had the straight pipes on, low end felt missing too.. i dont know if its a myth or perception, but it drove me crazy
Banned
Destroying a myth.
Some say that "an engine needs backpressure to work correctly." Is this true?
No. It would be more correct to say, "a perfectly stock engine that cannot adjust its fuel delivery needs backpressure to work correctly." This idea is a myth. As with all myths, however, there is a hint of fact with this one. Particularly, some people equate backpressure with torque, and others fear that too little backpressure will lead to valve burning.
The first reason why people say "backpressure is good" is because they believe that increased backpressure by itself will increase torque, particularly with a stock exhaust manifold. Granted, some stock manifolds act somewhat like performance headers at low RPM, but these manifolds will exhibit poor performance at higher RPM. This, however does not automatically lead to the conclusion that backpressure produces more torque. The increase in torque is not due to backpressure, but to the effects of changes in fuel/air mixture, which will be described in more detail below.
The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure.
The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well.
Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating.
Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust because of the way that backpressure caused air to flow backwards through the carburetor after the air already got loaded down with fuel, and caused the air to receive a second load of fuel. While a bad design, it was nonetheless used in a lot of vehicles. Once these vehicles received performance mods that reduced backpressure, they no longer had that double-loading effect, and then tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
- Adapted from Thomas V.
you do not make power with back pressure,straight up fact.when you put the straight pipe on,you moved the power band up.example,mufflers on powerband is 1500to 5500,mufflers off powerband is 2000 to 6000.
Well said sir! :D
Banned
no, sorry, its a proven fact
whereas you dont lose the power, you shift it up in the band, which results in a loss of low end, moving the power up higher
You are wrong. It is physcially impossible for "backpressure" to cause a combustion engine to lose torque. Low end or any other kind of end.
1 - 20 of 92 Posts
Status
