21 - 25 of 25 Posts
2004 M6 PMB
Hmm, I have one of his original hand made flat top intake.
Just always cleaned and reoiled.
Will check the dimensions.
Doing the Mid-life thang!!!
Discussion Starter · #22 ·
It's made of fiberglass. You're talking about it being shallow by an ~1/8" on each side of the long end, and a .44" taller on the wide end. You should be able to easily modify the opening to fit the new filter, or buy some paper filters for a TR-7 and see which one fits the best.
True. Thanks man...I have gotten lazy with my old age. Lol
Discussion Starter · #23 ·
I have the original flat design also. The rubber around the filter is cracked so it’s DONE. But I did get a replacement from a part number above. I will just trim a bit if necessary. Thanks for your help though.
I read on a thread once that they used the 33-2011 filter as a replacement for the original svede. They had said it looked different but fit in just fine. I too have one of the original ones with the old filter I actually just received my new filter a few days ago. My car is down so I haven’t tested it but can if you haven’t pulled the trigger on a new one yet. They aren’t cheap at 70$ but this is the cheapest I have ever seen them. They’re usually 84$ Plus tax 😅
Monaro, Ute, Commodore wagon
Apologies for reviving a fairly old thread, but 33-2522 are unobtainable as has been covered and I have picked up a 33-2011 instead.
Fits fine for my SvedeSpeed, picture below of the rear, the size is as good as the same, it's just the front surround that is a slightly different shape, but it fits in fine.
Rectangle Wood Door Road surface Brick
21 - 25 of 25 Posts
