Does anyone in the area happen to have a Tech 2 scanner? I live the Severn, MD area and am having "car start" problems. Security lock is flashing on dash and has killed everything. The key won't even pop the trunk. I tried my spare and that one won't work either. Ordered a new key fob from GTOG8TA.com and should be here tomorrow just to see if that would work.
You can get in the car and turn the key to on and everything works except to actually start the car (won't even click) which is leading me to believe its a dead key? You can manually unlock/lock the doors, but not remotely.
Also tried disconnecting/reconnecting battery and noticed that you don't even get that "sparking" when you reconnect the pos terminal on the battery (which is fully charged).
HELP! :banghead:
HELP! :banghead:
