1 - 20 of 26 Posts
GO STEELERS!
:hail:
Can't help ya, Sorry.
Not likely. That car uses 2 MAF sensors. GM has never produced a production model with 2 MAF's.
Cool as heck though..
Captain Thread Killer returns
has anyone?
Elegant. Talk about ram air!
Way cool, but what about operation in Louisiana's monsoon season?
I've been looking for this pics for a couple days. This simple elegant design solves two problems...i.e. cold air into the engine and functional hood scopes. The K.I.S.S. system never fails. Do you have the picture with the hood down?
go to the search function and type woodward and you will see many pics of the car
GO STEELERS!
Discussion Starter · #10 ·
Here are the specs on the engine....
All engine parts are from the Gen IV small block family
Engine Displacement: 6.4L (389 CID)
Bore: 105.03mm (4.135” )
Stroke: 92.00mm (3.622” )
REV Limit: 7000 RPM
Peak Hp: 575 Hp @ 6800 RPM
Peak Tq: 500 Lb-Ft @ 5200 RPM
Compression Ratio: 10.5:1
Cam Shaft: Custom GM Hyd Roller
Valve lift: 15.75mm (.620” )
Cam Duration Int: 232 deg @ .050” Tappet
Cam Duration Exh: 272 deg @ .050” Tappet
90mm Throttle Body
Dual Mass Air Flow sensors, Cold air induction system
Upstairs in the basement
I also see a drive by wire TB in there. I would bet there is also a way to get it down to just one MAF if they really really tried hard enough. :D
"YELOJKT"
Does anyone no for sure if the LS7 is going to be 6.4L or 7.0L?
"YELOJKT"
GTPprix said:
6.4L 110% sure.
Yea, I thought it was going to be 6.4L based on a list of GM RPO codes that someone posted about a year ago. I've read others places that people are speculating that it is going to be 427 ci or 7.0L. A 6.4L sounds more realistic. Has it been confirmed that the LS7 will be a 3V?
Hi, welcome to last week. :)
I hack cars.
I know I'm the one that posted it last time :) SEARCH PEOPLE SEARCH! :D
JFLS6 said:
Hey can you pm me some info on this. I am very interested in new RPOs.
Jeremy Formato
Hey man welcome aboard.....
1 - 20 of 26 Posts
