Some of the latest things I've accomplished on the car.
I managed to clean everything again. I Por-15'd the tubson all sides (trunk, iunterior and wheel wells. I then coated everything (trunk and interior) with Rust encapsulator (in case I missed something, followed by primer and a ligt coat of Brazen Orange paint. I used some sound deadner in the interior of the car (wheel wells, under the back seat, under the carpet and inside of the rear quarter)
Then I test fit the rear seat. The bottom section went in nice. The top section was...well...at least the bottom section went in nice!!!
After I tried the top section, it was NOT going to go in without a fight. I had to remove the leather and then pull back the foam to see the wire frame. I ended up bending the side bolsters in about 2 to 3 inches per side. I then put it back together and testfit it....
WOO-HOO!!! It wnet RIGHT in place with a little bit of sungness on each side...
The leather is a little wrinkled, but I' sure that will reteact back on itself over time. Then it ame time to pull out the rear speaker panel. I forgot, I needed to address a scratch on the drivers side speaker grille (WHOOPS!! 🤦♂️).
There was a small dent (hardly noticable), but the scratch was like a sore thumb. I bought the car with the speaker grille scratch, and it ALWAYS drove me CRaZy. Every time I walked up to the car, I saw that eye sore EVERY TIME! Of cource, I had to wait until the 11th hour to fix the prolblem.
It wasn't difficult to address at all. The hardest part was removing the grille.
When I turned the grille over...well, there was a bigger problem (depending on how you look at it). RUST! Seriously?!? Rust on the bottom of the speaker grille....
I broke out the Rustoleum Rust Dissolver and within a few minutes, it went from:
To completely rust free!!!
With the slight dent removed and a fresh coat of paint, these things looks spectacular. There is a LOT for me to gloat about on this car, but this is one thing that ALWAYS drew my eye and detracted from the car in an acute way, but was always 🔩'd with my 🧠...like "Chinese Water Torture".
So glad that's gone!
Currently, I'm waiting for the acoustic foam sponge to arrive (tomorrow), so I can re-assemble this and get the back seat reinstalled. I should have taken pictures of the rear panels, but they were a LOT more difficult to 'massage' back into place.
I then decided, I needed to run the new fuel lines (to and fro) the tank. While I was working on that, I came across this lovely part. This is what your evap line, fuel line and brake lines are partially protected by. It's held in place by 2 10
mm screws and 4 plastic 10
mm bolts. The amount if rust on this was not bad, it was...just...encapsulated by the rust.
After sandblasting it....and eventually paint
...the last pic wont upload. :-(
Anyway, I got something accomplished on the car this weekend.
