1 - 14 of 14 Posts
DAAAT'S RIGHT
Anyone have a list of the top speeds for each gear @ stock redline, excluding 6th? I know you'll hit the speed limiter first. The only one I know for sure is 4th. I hit 132 on the dyno before 6200rpm.
Yep, used my calculation spreadsheet:
1st Gear 46.4
2nd Gear 66.6
3rd Gear 96.5
4th Gear 137.9
5th Gear 164.2
6th Gear 242.0
This is with a 6250 rpm red line
-Steve
DAAAT'S RIGHT
Thanks Steve!
Wooohooo
DevilYellow said:
I've been in 2nd gear goin 95mph (approx) twice.
Do you mean 3rd??
Enjoy the trolls
1st Gear 46.4
2nd Gear 66.6
3rd Gear 96.5
4th Gear 137.9
5th Gear 164.2
6th Gear 242.0
-Steve
I need a new speedometer. Mine only goes to 200 mph. Damn!
Great Lakes Moderator
DAAAT'S RIGHT
Discussion Starter · #10 ·
I've done that once before myself DY. How the crap is it possible, I mean it's straight down!?!
Can't help ya, Sorry.
I've down shifted early doing a 0-60 run. I shift to 3rd to hit 60 quicker because the HP and torgue starts rolling off @ 5400 RPM. If I shift into third @ 5400 RMP I pull a slightly quicker time. The problem comes when I hit the breaks, I instinctivly down shift as I am breaking and I am usualy doing @ 80. I have never fully engaged the clutch, just a bounce and awsnit, back to 3rd. I have completely missed the gear and over reved.
DAAAT'S RIGHT
Discussion Starter · #12 ·
You bring up an interesting point. The LS1's power does start to fall off @ about 5500. Anyone else shift there instead of running it to 6xxxrpm? If so, with what results?
Sea-Doo RXP 215 HP!!!
On my gtech pro with a stock goat, I can get consistently low 5.3's on 0-60 when i shift into third at 5400. Whereas when i stay in second until sixty in is consistently 5.6's.
The decrease in 0-60mph by shifting to 3rd gear could be the initial jerk that occurs when you shift, and since that happens so close to 60mph, it could be giving a false reading.
1 - 14 of 14 Posts
