This is what i meantI think Sacrifice was stating that you shouldn't use longer bolts to draw the transmission in on the alignment dowels. Point being, if you can't get the transmission in far enough that the stock bolts can be started and then used to draw it onto the dowels it isn't in far enough and something is out of alignment, most likely the input shaft isn't yet started properly into the pilot bearing. If you were to use longer bolts to draw it in you could damage something. And I also suspect the longer bolts would bottom out before the trans is fully bolted to the bellhousing.
