1 - 8 of 8 Posts
The transmissions cooling lines on an A4 are routed into the on the drivers side of the radiator (the rubber hoses).
Does any one know which line is the supply line and which line is the return line?
Thanks
Wow no reply, I just did a search becuase I'm looking for this info as well. Is the top line from the trans feed to cool, then the lower one returns to the tranny?
Anyone?
Great thanks, so on the radiator, the top line is "IN" and the lower line is "OUT"?
I should install the trans cooler between the lower line.
Thanks for the help!
1 - 8 of 8 Posts
