1 - 4 of 4 Posts
Banned
Does Anyone Know If The Replacement Of A Steering Column Requires Any Tty Bolts Per The Manual?
How Many Tty Bolts Are Needed For The New Diff Install?
Banned
Thanx Will Check... I Assume This Is For The Rear End Only
The dealer indicated that the manual states you should remove the complete craddle. they said they could do the pumpkin only and leave the craddle in, is this ok or a bad idea. if this is the case can you specify what bolts should be replaced?
1 - 4 of 4 Posts
