There's always the secret menu for a digital temp reading. Not practical for everyday but if you're doing something that will push temps to 215 and above you could set it up.
[incar-cluster]$ listports
COM1
COM5
COM4
[incar-cluster]$ open com4
serial port opened successfully
[incar-cluster-com4]#
[incar-cluster-com4]# listen
==Heartbeat==
Module:b8 Mode:A2 Data:B8
Module:b9 Mode:02 Data:00,00
Module:40 Mode:C6 Data:39,02
Module:BCM-data Mode:12 Data:00,00,00,3D,19,00,00,70,F2,1E,00,00,10,00,00,00,94,00
Module:a8 Mode:03 Data:
Module:20 Mode:8B Data:
Module:21 Mode:09 Data:38,2C,00,00,00,00,00,94,94
Module:90 Mode:1B Data:
Module:91 Mode:03 Data:18,00,00
Module:a0 Mode:0B Data:
Module:Airbag-data Mode:02 Data:08,00
Module:Transmission-data Mode:07 Data:FF,10,40,05,00,00,00
[incar-cluster-com4]# read 9
Waiting for heartbeat...
Send: ['F2', '57', '01', '09', 'AD']
['01', '09', '05', '00', '00', '00', '00', '00', '50', '79', '7C', '7E', '7E', '7E',
'60', '80', '00', '00', '00', '00', '00', '00', '00', '00', '00', '00', '00']
ALDL Mode: 0x1 (read configuration table) Table: 0x9
Startup Logo: Pontiac
HSV Serial: 0
HSV Model: XU6
Cold shiftlight 4000 RPM
1st gear shiftlight 6000 RPM
2nd gear shiftlight 6200 RPM
3rd gear shiftlight 6300 RPM
4th gear shiftlight 6300 RPM
5th gear shiftlight 6300 RPM
Shift light on: False
Custom text:> <
[incar-cluster-com4]# preset shiftlight-on
===Current Config===
HSV Serial: 0
HSV Model: XU6
Custom text:> <
===New Config===
'60', '90', '00', '00', '00', '00', '00', '00', '00', '00', '00', '0 '00']
HSV Serial: 0
HSV Model: XU6
Shift light on: True
Custom text:> <
===Write config===
Send: ['F2', '70', '28', '09', '05', '00', '00', '00', '00', '00', '50', '79', '7C', '7E', '7E', '7E',
'60', '90', '00', '00', '00', '00', '00', '00', '00', '00', '00', '00', '00', 'B9']
['28', '09', '01']
I just tested it on a Windows 11 machine, and I was able to connect and read just fine. Didn't try writing anything though. Laptop was not on wifi at the time, and Windows said it could not connect to SmartScreen, but I just chose to run anyways.Is anyone having luck using this on Windows 11?
I can connect to the com port but not much after that. I can post errors when I get home.What problem are you having?
If you're using VZClusterMod I'm guessing youre reading from the Cluster module, and all that's defined in the code for table 2 is the odometer so there's plenty to work out!!Can anyone help me out with table 2?
PM is fine if you don't wish to discuss privately
If that's aimed at me... Not at the moment!Would an xdf and bin file using Tunerpro help?
Do you have the background lighting turned up all the way? Mine are way too bright at the highest setting, I have them dimmed quite a ways.@Sturdy… it would be great if you can develop it some more, especially to make it more user friendly. I was able to go through it and turn on my shift light, change the coolant gauge reading and adjust the tach for the 05-06 gauge face (swapped on to an 04 cluster). I followed directions and got it done but otherwise, I was completely clueless to it, not going to lie. I’d like to know if gauge calibration is possible, along with adjusting the brightness of the lighting, not the LCD screen but the background lighting. It could be a touch brighter in my opinion. Regardless, kudos to you for tinkering with it and trying to learn more.
Yes, they are turned up all the way.Do you have the background lighting turned up all the way? Mine are way too bright at the highest setting, I have them dimmed quite a ways.
