81 - 100 of 115 Posts
The Entenmann's Shim-Sham
Sweet. Even came with C5Z wheels.
Not really. But if your son can reach the bottom of the tank. I think it's like 8 bolts around the filler and to get the pump out. Easy peasy. He can scoop it out and then use rags to soak up what's left.
Can't remove spark plugs
I dunno if it's major surgery by some standards, but I sprung a timing chain gasket leak back in October. We also decided to replace the water pump/hoses/radiator because they were looking pretty rough and are 20 years old. New Hoses are Silicone so will last a ridiculously long time, radiator is now aluminum so a bit of weight is taken off.
I also had to replace the fan because the bearing went bad and the blades were chewing themselves up on the shroud. My viper has a small offset fan, newer Gen 2 Vipers have a large center fan. I'll be upgrading to the larger fan so that's a perk.
It's not the exhaust system like I wanted to do, but at least this way I can hit the drag strip/autox with little worries on the cooling system!
Seriously?
Discussion Starter #92
Well, it is going to be a little bit before I can buy one. The plus side is that I will be starting a new job in February and when I hit top rate, 6 figures should be obtainable. I need a bigger garage so buying a bigger house will be priority number 1. On the plus side, the GTO will remain in the stable.
That's good. Clean GTOs are hard to come by nowadays.
Seriously?
Discussion Starter #94
They are... It pains me to see a ragged out one going down the road. I know for a fact that if I sold mine I will regret it and trying to find one as immaculate as mine will be a bitch. C4s are just a ridiculous bargain for what they are and I hope I can jump in one while the getting is still good.
Yeah. My hope is to find a C4 roller and drop a 302 into it.
I've been debating on buying a reasonably used C5 or even C6 for a daily... winters up here suck but I bet blizzak's or mich X-Ice's would do the trick. I'll have to do more research but for as cool as say the ATS-V or Quadrifoglio is, I suspect you can get the same/better perf for the dollar in Corvette land.
I think ground clearance would be the main issue. Blizzaks can only help so much when the snout starts acting as a plow.
