1 - 7 of 7 Posts
Evil SS
Does anyone know what head unit the Vortech Supercharger kit uses for the GTO. Can you upgrade to a YS trim or a YSi trim?
TBYRNE Performance
They might be using the V9. This is just my option so don't hold me to it. I'll see if I can get you a firm answer. Any head upgrades will have to be custom.
Evil SS
Discussion Starter · #5 ·
Some tuners have made close to 800 rwhp without going to a DFI.
Im in the middle of doing a ACCEL GEN 7 DFI for my 2001 Camaro SS.
Admin
Stock PCM's on f-bodies are programmed staticly for boost, they can not dynamically adjust. Even if they can force a constant open loop program and run 60lb high impedance injectors does not mean its properly fitted for the application.
Fasttrack better have their f-body harness ready soon! You will be able to piggy back that Gen7 onto the stock PCM to keep the factory gauges and OBDII systems.
My guess is the V2 SQ. It's whats on the LS1 Fbods and 04 Vettes. I'd be leery of any change. The Vortech kits are very thoroughly worked out for their applications. I'd just as soon let them do the math.
1 - 7 of 7 Posts
