1 - 10 of 10 Posts
I want to replace the stock differential with a Torsen T2R, but I haven't been able to figure out what kind of rear end is under our car.
Given that information I will be able to learn whether I can replace the differential with the Torsen.
Anyone know what the specs on the rear are?
Thanks!!
Jim Howard
2004 Red/Red M6
Single Digit Stick Shift
The rearend in our cars is a Dana derived 8.5" ring gear rear end. I have replaced the gears in my rearend and am glad I did it. There are other posts about the rear diff information in this section and there are posts about the bearings, and seals in the part numbers threads. I believe I once saw a post that said they were purchasing a bulk load of 3.73 rear gears. Hope this helps.
Thanks for the heads up. I searched around and learned the following.
As you mentioned, it is "Dana derived" with a 8.5" ring gear and I learned that it is a Borg Warner Hydra Track Viscous LSD (crap).
However, I need to know which "Dana" axle is in the car. Is it a 30, 35, 44, etc? And do Dana 8.5" units work in the car? What is the axle spline count and so on.
Anyone?
Thanks!
Jim
Knight Errant
You'll probably have to....
Anyone?
Thanks!
Jim
Check with a Dealer's Parts folks. The Helms tells you all about takeout, repair, replace, etc., but is largely devoid of details about the makeup of the parts and numbers. I wish they made a specifications book. :(
Discussion Starter · #5 ·
I have been corresponding with Torsen and they also have not been able to determine whether their unit will fit our GTOs. They have a request into GM for the information, but have not received a response yet.
Jim
Discussion Starter · #7 ·
LS1GURU said:
The Diff is not a viscous locker.It is a cone style locker with 4 spider gears.
I am not saying that you are incorrect, but that was just what I gleened from another post earlier on in this group.
A cone style is definitely better, but will wear out quickly. So, in the end it is irrelevant about what type of differential is in there. I am going to replace it anyway.
Any idea about whether a Torsen T2R will fit?
What type of axle is in the GTO?, etc.?
Thanks!
Jim
Jim. I have been in one of these diffs and have changed gears.It was a cone type.I took the carrier apart and verified what was inside.No one has made any other carrier that will fit in this diff that I know of.
Discussion Starter · #9 ·
Thanks for the confirmation. While the cone type diff is definitely better than a viscous type, I would still like to replace it with a Torsen.
There are other things that I would like to modify about this car to improve performance and I am learning that our cars have two strikes: 1) the car is from a foreign land and most performance folks locally have no idea what the car is yet: 2) the car is new (to USA) and performance parts have not been established for the car.
Just have to be patient I guess.
Thanks!
Jim
Knight Errant
Positraction Unit
Did it look like an Auburn? People I have spoken to are under the impression it was a Torsen unit already, but that now appears to be incorrect if you did not recognize it as such.
1 - 10 of 10 Posts
