1 - 15 of 15 Posts
Drag bags are air bags that inflate within your rear mini bloc coil springs. The inflated bag reduces the coil movement and can virtually eliminate spring movement with enough air pressure. Adjustable dampers controls the speed at which a coil reacts on bound and rebound.
The two functions are completely different.
Not a winner?
but i thought that if you tighten the shocks and don't allow for so much movement. it would do the same thing as what the drag bags do to reduce wheel hop
da slow kid of the bunch
I'll take shocks over bags any day.. now if I could just fine a GOOD drag racing set I'd be happy..
Dampers DAMP the rate at which the spring reacts. Spring rate and damper rate should be matched. The OE spring rate is too low and combines with soft damping rates and x member bushes to create wheel tramp / wheel hop. The correct fix for wheel tramp is to alter the harmonics of the IRS by increasing the rate of coil and damping while upgrading the OE x member bushes to urethane bits.
Not a winner?
what i wanted to do was hook up the drag bags and some how have an electric pump or compressor of some kind that i can just flick a switch and inflate them.
Not a winner?
well what i wanted was to also have an all around car. if i'm gonna get the gears to make the run then i would like to not have wheel hop so i can still be fast from the dig.
jamesbiz said:
so then what do you recommend
04/05/06 GTO Track eXtreme
(2) 2641 GTO Rear Coil Low 1 1/4" Drop $ 90.00
(1) 4658 GTO GSR Strut Tower Bar NEW $ 182.82
(1) 5403 GTO Rear Camber Kit NEW $ 138.18
(2) 5409 GTO HD Radius Rod Arm NEW $ 59.09
(2) 5851 GTO Strut Mount NEW $ 35.45
(2) 9195 GTO GSR Big Bore Rear Shock NEW $ 135.45
(2) 424209 GTO Front Sway Bar HD Endlinks $ 50.00
(1) E9986L GTO eXtreme X Coilover Adjustable 1/2" to 1 1/2" Drop $ 453.64
(1) E9986R GTO eXtreme X Coilover Adjustable 1/2" to 1 1/2" Drop $ 453.64
(1) EP1145 GTO X Member Mount $ 156.36
(1) EP1157 GTO Urethane Differential Insert February 05 $ 49.90 or a Harrop Cover using 5807 Steel Jacketed Bushes Bushes
(1) EP2105 Steering Bush kit $ 20.00
(1) EP513 GTO Rear Sway Bar $ 25.46
(1) EP613/17 GTO Rear Sway Bar $ 17.27
(1) EP6500 GTO Lower Inner Urethane Control Arm Bush $ 42.00
(1) EP7023 GTO IRS Inner Lower Arm Urethane Bush $ 38.13
(1) EP9019 GTO Urethane Radius Rod Bush Rear Bush NEW $ 27.27
(1) EP9166 GTO Castor Adjustable Radius Rod Front Bush $ 240.91
(1) EPC27 GTO Front Sway Bar $ 18.80
04/05/06 GTO Track eXtreme $ 2,604.36
This will be the most stable setup for a 200 MPH run. You should have your car aligned at a Pedders shop including the front cradle, rear cradle, transmission centralization and four wheel alignment. At 200 MPH you'll also want to have your tires and wheels road force balanced. You should also be running a safety loop on your drive shaft. Your local Pedders Dealer will be a valuable resource in your 200 MPH quest.
Not a winner?
Discussion Starter #11
jeez. thats a lot of parts. am i right to assume that the set up will cost over 4k after everything is said and done? got any cheaper options for me? for the moment i just want to do it once and then put a little more money into it to make my car even more stable.
At 200 MPH you may only get one chance at that speed. The first time is the most dangerous. Do everything right the first time out.
If you are just drag racing, get the bags. They work really well and are cheap. If you road race, or want the suspension to be "better" all the time, get a full suspension setup.
Full suspenion does not always kill all wheel hop though, so keep that in mind.
1 - 15 of 15 Posts
