1 - 10 of 10 Posts
The difference between the LS1 and LS6 is easy.... Is the LS2 an entirely new engine, or different stuff packed in and on the LS1 block? The new motor trend indicates that GM has a version of the LS2 that is "between 700 and 725 HP"..... that would be NICE!
Gone but not forgotten
same block. slightly longer stroke=6.0L, instead of 5.7L. 15lbs lighter than LS1. 400HP. Displacement on demand.
Admin
The orginal LS1 shared very little parts with the LS6. The LS6 has much nicer heads, block, intake manifold, etc. Now a days they use the LS6 block and intake manifold when building LS1's.
The LS2 is another step beyond the LS6. 400HP (non-DOD for GTO/C6). Think of an LS6 6.0L. After more shops tear them down I'm sure there will be some differences that they will notice.
This suprised me. I would have expected a larger bore instead. Is the compression the same?
mlc said:
thanks.
This says it does have a larger bore.
DY. when are we gong to see pictures of the new colors?
hmm, interesting. could have sworn that someone said it was the same bore.
Now lemme see this straight.. If I wanted to turn my engine into ls6. I already have intake manifold as i know, so i will need ls6 cams, springs, and heads???? are pistons and rods the same as ls1?
1 - 10 of 10 Posts
