Hi, I’ve just recently got to a place to where I’m trying to fix my suspension problems, as I’m tired of everything from wheel hop to spring sag. I’ve got a game plan for everything but my rear control arm bushings. I’ve seen a lot of division on whether or not I should go full solid bushings (inner and outer) or to ditch the toe rod and go with adjustable ones.
With that in mind, I would like some clarification about the adjustable route. I was wanting to know if only one bushing is replaced with the adjustable camber sleeve and the other on the same arm solid, or do both need to be adjustable?
This car is just a bolt on daily, no track use and I do not push it very hard often, just some light highway pulls and some harder than average street take off and cornering.
