Holy crap!
As somebody with the Wilwoods on my wish list, I'll be watching this thread.
I'll be getting pics once I get the new lines from Wilwood (it's taking them a couple of days already to get them to me). These are the lines you have to use when you install the wilwood kits. I'll have them examined by a couple of brake shops to get a clearer idea of what happened.Riddlefox said:Scary.. pics? What exactly failed? Were the lines coated or uncoated?
These are the lines that Wilwood requires for their brakes. Are there better lines that will fit?MidwestPd said:This is not uncommon with crappy lines. We have seen it numerous times.
berjet said:Yes, i did. I had both rear fail on mine. I went ahead and made custom lines SS fitting and ss lines. I couldn't use the factory supplied 90 deg fitting coming out of the rear calibers (lines hit tires/wheels) so i got straight fittings. When the car moved up and down on the suspension, the shock hit and broke both lines (car is dropped about 1/2 inch w/ pedders extreme kit). my fronts seem to be ok so far but i have been keeping an eye on them. I think it would be better if they had a 90 or 45 degree fitting instead of the straight fitting they used. I have been thinking about making new lines this winter.
Henry, how did you rought the lines? can you post some pics to how the lines were roughted and were they broke? also is your car dropped at all?
As to Midwest's comment, I hate to admit it but they are right. I have the stoptech chassis to subframe ss lines in the rear and they are of much better quality than the wilwood lines IMOA.
