1 - 6 of 6 Posts
I'm in need of a LS2 power steering bracket (that bolts to the head) and the reservoir bracket or if you have the reservoir and bracket together that would be good too. This is out of a 2005/2006 GTO.
Thanks
It's only cosmetic...
These are both available new if nobody has any to sell.
Edit: the reservoir is available new. I do not know about the pump adapter.
Edit 2: pump adapter is available new from several aftermarket companies
I can easily find the reservoir and the p/s pump adapter block BUT the reservoir bracket is next to impossible to find.
gtog8ta sells them.
or at least he did. i haven't checked his site recently. a bit of his stuff is actually NOS so when he runs out, it's out.
Hmm. This is one of at least 7 listings that come up when I did a search for 2006 GTO power steering reservoir bracket. This is even the first link after the ones on top in the shopping section.
That's pretty hefty for a simple bracket. I was figuring someone had one laying around beatup
Used condition. I may just fab something up.
1 - 6 of 6 Posts
