1 - 5 of 5 Posts
Greeetings,
I am planning on installing an XM Commander in the next few days. Has anyone installed this and direct wired to the factory head unit? What wiring harness is required? I would like to avoid FM modulation if at all possible.
Thanks.
Discussion Starter · #2 ·
Thanks for the information. Just to confirm - your installation is tapping into the antenna lead and using the FM modulation output - correct? Is there any option for using the audio out RCA connectors into the head unit?
Thanks.
Twister said:
Greeetings,
Thanks.
I too am looking to find out if you can install an AUX adapter to the factory radio. So far I have not had any luck getting an answer. I want to install the XM SkyFI radio but I don't want to use an FM modulator. Let me know if you have nay luck getting an answer.
The only input the radio has is a mono cell phone jack. We're pretty much limited to FM modulation for XM.
for what its worth,i installed trhe new Roady in my GTO and DURAMAX.FM Modulator is built in to the unit and the antenna&wire are small and eazy to run and hide.Radio play just outstanding.
1 - 5 of 5 Posts
