Brand new. I bought it for a computer that ended up having a board issue rather than power supply. I tested this one to be sure it wasn't bad from the start, and it worked. Uninstalled and boxed up. You can find the same model on Newegg for $45 + shipping.
$30 shipped.
Description:
Brand Antec
Model EA-380D Green
Series EarthWatts Green
Spec
Type ATX12V v2.3 / EPS12V
Maximum Power 380W Continuous power
Fans 80mm low noise cooling fan
PFC Active
Main Connector 20+4Pin
+12V Rails 2
PCI-Express Connector 1 x 6-Pin
SATA Power Connector 5
SLI No
CrossFire No
Energy-Efficient 80 PLUS BRONZE Certified
Over Voltage Protection Yes
Input Voltage 100 - 240 V
Input Frequency Range 47 - 63 Hz
Output +3.3V@20A,+5V@20A,+12V1@17A,+12V2@15A,-12V@0.8A, +5VSB@2.5A
Approvals UL, CUL, FCC, TUV, CE, CB, C-tick, CCC, BSMI
Dimensions 3.4" x 5.9" x 5.5"
Weight 3.6 lbs.
Features
Connectors 1 x Main connector (20+4Pin)
1 x 4+4 Pin ATX/EPS 12V
4 x Peripheral
5 x SATA
1 x Floppy
1 x PCI-E
$30 shipped.
Description:
Brand Antec
Model EA-380D Green
Spec
PFC Active
+12V Rails 2
SLI No
CrossFire No
Weight 3.6 lbs.
Features
4 x Peripheral
5 x SATA
1 x Floppy
1 x PCI-E
