hello. so i just replaced my strut mounts on a 04 GTO and had the car realigned. Spec sheet shows the final caster on the right side set to 9.42 degrees, left at 8.32 degrees. Camber and toe are within OE specs. Is the right side caster too much? This car is just street driven.
In addition now I am hearing a slight thunk when making hard right or hard left turn. I may have left something loose which I am looking over this weekend since I am changing the brake pads. Any thoughts what it might be besides something being loose or not torqued enough.
Thanks.
Thanks.
