I know somebody has fit 305's without mini rubbing, so I'm curious, just how much fender modification does it takes to fit a 295 tire on a 9.5 rim with et50 offset? My fender lips are rolled and the wheel well has been "massaged."
Check your tires again, brah guy. No such size exists on the NT05Rs.I've got 295/40/18 NT05R on the rear with BC shocks and no spacers. The wheel lip is cut, though.
More intelligent advice, OP...295 NT05s on my 10.5" C5Z wheels. I can only imagine that they would bulge out on a 9.5" wheel. I'd personally go for a nice, sticky, proper sized tire instead of squeezing something on there that wasn't meant to be.
Your contact patch will be as wide as your wheel. The excess tire will curve up, since the sidewall is being compressed inwards to fit such a wide tire on a narrow wheel.A bulged tire will arc the tread in the center at say 35 psi. When you drop the psi down to 20 or whatever you like, you will have a more horizontal contact patch increasing grip.
That doesn't look bad at all. It actually looks good. If, as you say, a 295 on 9.5 wheel would look like that, I wouldn't have any issues putting it on a 9.5 wheel.Here is a 285/35R18 on a 9.25" wheel. I would expect 295 on a 9.5" wheel to look about the same. Of course you are bellow the recommended wheel widths.
Do you have any pics? Also, what would you say your driving impressions are with a 295 on a 9.5? It's good to hear from someone that's done it and can give honest informative information to determine whether it's worth it or not.My 295 don't look pinched at all on the 9.5" wheels.
If you deflate those tires and run the same test you will get more dirt farther out because the carcass will pull inward due to less air pressure. As the carcass pulls in the sidewalls will become more vertical reducing the curved raised portion. It won't be perfect because those are way stuffed on there but it will go further out as the sidewalls take more load. 295s on a 9.5 will not look like that all.Your contact patch will be as wide as your wheel. The excess tire will curve up, since the sidewall is being compressed inwards to fit such a wide tire on a narrow wheel.
Look at these wheels. When rolled along the ground, look at the contact patch it made. Then look at the black lines where there is no dirt. That's essentially what the contact patch will be when they are mounted, even with the weight of a car.
Imagine for a moment, an inflatable pool toy sitting in your driveway. It will curve up at the edges. Now imagine sitting on that pool toy in your driveway. The edges will curve up even more, as the direction of your weight pushes down.
In the context of this thread, the tires would be the pool toy, and your body would be the wheels. Lowing the PSI wouldn't do anything except exacerbate the bulge. Certainly the effect would be less pronounced than the pool toy, since the tires will be stiffer, but the idea remains.
OP - get tires that were designed to fit on your wheel.
