Hi all,
I had my car throw the first ever CEL the other day and it was the P0332. Makes sense since I just had some tranny work done and they were right in that area. So I searched here and sure enough I had the wire and sensor sitting on my slp header and there is a slight black mark from where it fried part of the wire harness above the sensor. I tried to zip tie the wire and sensor above the header and cleared the code and it came back so now I am trying to figure out what to do. The sensor itself is only like $12 but that doesn't include the wire harness. Since it was the wire that got fried, I'm thinking I need to replace that too? I can't seem to find the part and neither can O'reilly. Take it to a dealership?
Another thing: this happened right after I got some BP 93 (from the same place I always go) and the car has been surging and stalling (like right when you first put it in drive) until it's warmed up. Could this code throw the car into limp mode/onto another map? I have extensive mods and tune work done to the car and it runs pretty much flawlessly so I'm hoping that since these two things came into being at the same time, they are related. Either the code is throwing the car into a backup map, or it's bad gas and a bad sensor.
TL;DR Should I replace the whole wire above the sensor and where do I get that shit? Could the code send my car into "limp mode" and moreover if it was in a backup map, will it come right back to the primary map once the problem is resolved?
Thanks in advance.
Thanks in advance.
