Tranny fluid pan drop 4l65e
8.9K views 5 replies 4 participants last post by  Iron Indian
#1 ·
How many quarts does the pan hold if I want to drop it and change the filter?
This post has been deleted
#2 ·
I didn't realize there is a drain plug?
#3 ·
I did mine awhile back and I think it was 6.5 quarts...I believe it says in your owners manual too
#4 ·
Mine took 10.5 quarts with an new converter and TCI deep pan (holds 2 extra quarts)
#5 ·
There is no drain plug, you have to drop the pan. Actually, mine does have a drain plug, but the pan is an aftermarket one. I deleted my original post because I was finding conflicting info about the capacity. I was thinking when I did a converter change I had to add 8 or 9 quarts, but I can't remember for sure. I would probably have at least 8 quarts on hand to start out.
#6 ·
For a pan drop it shouldn't be that much. I know when I pulled my tranny for the cooler and the stall it took 9-10 quarts of fluid then. Pan drop should be like 6 or 7 but i can't remember for the life of me.
Oh and the stock pan has no drain plug, you have to pull the pan.
