Pedders Bump stops?
7.5K views 18 replies 11 participants last post by  esau999
#1 ·
I about to put some SuperPro strut mounts and bearings, Pedders 0 drop front springs on stock struts.
From what I've been reading it's a good idea to get new bump stops while I have everything apart?
Went to Pedders website, actually PM'd DMS(no reply).
On the website it says 1 per vehicle, that can't be right?
Need one for each strut right?
So that would be $72 for two yikes. Anybody else make these?
4358
Pont GTO Bump Stop Front
Pontiac GTO Bump Stop Front - 1 Per Vehicle
Retail $36.12EA
Mike
#2 ·
I know this doesnt really help, but when I replaced my bump stops on my Cobalt SS/SC each stock one was $75. So $36 each for Pedders really isnt that bad (can only imagine they are better than stock- dont really know how but you get the pt)
#3 ·
#4 ·
That stupid boot doesn't fit our cars. It's universal of some sort.
Mikey, since you're not driving the car, take the struts off, disassemble them, and inspect the bump stops. Maybe they will be perfectly fine. My stocks ones looked great after 50K.
#5 ·
I think the DIY community really do not check these. The last 20 or so GTOs that I have done, I have not seen one that was not damaged. This is why we have added the bump stops to all systems.
The bump stops are the same on the G8. Mike Haddad's G8 had the worse bump stops I have ever seen. Everyone who knows Mike knows he is one of the most aggressive drivers out there.
and he only had 6k miles on them when we did his Track II on his G8
Here is what the Pedders units are, and think they are a much better value than OEM
4358 GTO Bump Stop Front Requires 2 packages $36.12
thanks
mike
dms
#11 ·
Looking at them, unless you are 100% knowlwdgable on what they look like or should look like, are often very deceiving. You need to lift up the outer end
Here is an extremely bad one that had about 6500 miles I think but driven seriously thru lots of mountain driving
Out of the last 15 GTOs that I have done, all were damaged. This is why we are now including bump stops with all packages involved with the dissassembly of the front struts
mike
dms
#12 ·
Were all of the bump stops off of stock suspended cars, or were any of them "pedderized"? I have a theory that stock springs destroy the bump stocks (they bottom out often and the bump stops serve as defacto springs).
#13 ·
It's a good theory, that. The OE ride height GTO only has 60-70mm
front suspension travel. Combine that with soft springs and the bumpstops
get used a lot. Combine it with soft aftermarket lowering springs and
the bumpstops still get used a lot.
It's preventable by using taller and/or stiffer springs. But it's not a
problem per-se - it's effectively a progressive spring. Quite a lot of
cars are designed that way.
I have my doubts about the way in which the OE bumpstops are
oriented, actually. They have a flat end and a pointy end. The
pointy end nicely matches the cupped washer at the top. The flat
end of the bumpstop nicely matches the top of the shock. But
they're installed the other way up, so the cupped washer cuts into
the flat end.
#18 ·
in process right now of replacing the strut mounts. The guy i bought them from sent me a new pair of bump stops, which are not only longer, but more concerning to me they are a smaller diameter? the old ones are toast, so i plan on installing these new ones, but just seems strange they don't fit snug in there like the originals. am i missing something here? i guess once everything's bolted in place there's really no side load or anything on the bump stop, so should be ok.
and as pointed out above by flink, i agree the bump stops look upside down. i'm putting the cupped side up to mate the cup washer and the flat side down to mate the flat side of the shock. it's the way these bump stops are intended, as if you look inside, the bore is larger toward the flat side, which makes sense as threads are toward the cupped side (smaller bore in bump stop). time to go get greasy again...
#19 ·
I changed mine about a month ago: they came with the Pedders tire rub kit. After 34K miles of relatively mild driving (compared to what I've seen), the bump stop on one side was damn near shredded and the lip of the other one on the other side was just beginning to split.
